Alex Zanardi Signature Edition,
1999 (wird noch weiter übersetzt
Eine eng begrenzte Stückzahl von nur 50 Zanardi NSX, "basierend auf dem japanischen Type-S" (kann wohl nicht stimmen, da dieser ja 45kg leichter als der normale NSX ist), wurde 1999 exklusiv auf dem US-Markt verkauft. Auch unter den schon ausgewählten NSX-Exklusiv-Händlern wurden damit nur die umsatzstärksten beliefert, so, daß sogar mancher NSX-Exklusiv-Händlern garkeinen bekam. Der Zanardi ist rund 24,49kg leichter als ein '97er coupe mit elektr. Servolenkung - the 149 lb weight reduction in the press material is vs. a -T which is about 95 lbs heavier than a coupe. This makes it heavier than either a Type S (99 lbs. lighter than a '97 coupe with power steering) and far heavier than a Type-S Zero which is over 211 lbs. lighter than a '97 coupe with power steering.
Alex Zanardi Signature Edition NSX
NOTE: There is a misprint in some of the Acura promotional material for the Zanardi Edition which states that the Final Drive Ratio is 4.6. This is incorrect. The final drive ratio is the same as the regular NSXs (4.062).
Acura Debuts Alex Zanardi Edition NSX
Miami, FL, Nov. 8. — Acura unveiled its most exclusive, best handling and quickest model ever at the Miami International Auto Show. The 1999 Alex Zanardi Edition NSX takes Acura's all-aluminum sports car to new levels of exclusiveness with a signature series model that comes with a number of distinctive features, including revised suspension and dedicated interior and exterior styling cues.
Available only as a hard-top coupe, the signature series NSX takes its name from two-time CART open-wheel racing championship driver, Alex Zanardi. Only fifty copies of this limited edition model will be hand built — each identified by a numbered, brushed aluminum, signature plaque engraved with Alex Zanardi's signature and located on the rear firewall between the driver and passenger seat head rests identifying the vehicle as one of only fifty to be hand built at the company's Takanazawa plant in Tochigi, Japan. Zanardi himself will take delivery of the first one when it goes on sale in March, 1999.
The Alex Zanardi Edition coupe features a lower overall heft than the standard NSX through a number of weight reducing measures. A racetrack-tuned suspension, lightweight BBS alloy wheels, titanium shift knob and signature series plaque are a few of the key elements that set this model apart. Total vehicle weight is reduced 149 pounds compared to the NSX-T, through the use of a fixed hard-top roof, lighter rear spoiler, single pane rear glass, lightweight BBS alloy wheels, a lighter battery, and a manual rack-and-pinion steering system in place of the electric power steering. Other features available only on the Alex Zanardi Edition NSX include a red-stitched interior trim with suede-like seating surfaces and aluminum-mesh intake covers.
Additional exclusive features include a new titanium-finished center console and door inserts, and perforated suede-like seating surfaces. An exclusive Formula Red exterior color completes the package.
The Alex Zanardi Edition is equipped with the NSX's 3.2-liter, DOHC, 24-valve, VTEC V-6 engine producing 290 horsepower and 224 lb.-ft. of torque, coupled to a 6-speed close-ratio manual transmission. The Alex Zanardi Edition takes performance up a notch, though, thanks to the improved power-to-weight ratio. It also boasts a racetrack- tuned suspension system and manual rack-and-pinion steering for increased steering precision and handling control.
