BAR Honda 007 technical specification.
Chassis
Construction- Moulded carbon fibre and honeycomb composite structure, surpasses FIA regulations.
Front suspension- Wishbone and pushrod-activated torsion springs and rockers, mechanical anti-roll bar.
Rear Suspension- Wishbone and pushrod-activated torsion springs and rockers, mechanical anti-roll bar.
Dampers- Showa.
Wheels- BBS forged magnesium.
Front – 312mm wide.
Rear- 340mm wide.
Tyres- Michelin.
Brakes- Alcon - Front – 2 x6 piston callipers - Rear - 2 x6 piston callipers.
Brakes discs/pads- Carbon/carbon.
Steering- BAR power assisted Rack and Pinion.
Steering Wheel- BAR carbon fibre construction.
Drivers seat- Anatomically formed carbon composition.
Seat Belts- Six point harness (75mm shoulder strap with HANS system)
Fuel Cell- ATL Kevlar-reinforced rubber bladder.
Fuel capacity- 150 litre.
Battery- 3 Ah lead acid.
Instrumentation- BAR steering wheel dash display.
Transmission
Gearbox- BAR maincase – 7-speed unit, Honda and XTrac internals.
Gear selection- Sequential, semi-automatic, hydraulic activation.
Clutch- Carbon Plate.
Dimensions
Front track- 1460mm.
Rear track- 1420mm.
Wheel base- 3140mm.
Overall length- 4675mm.
Overall height- 950mm .
Overall width- 1800mm.
Engine
Name- Honda RA005E.
Displacement- 3.0 litres.
Vee Angle- 90 degrees.
Maximum power- Over 900 ps.
Maximum revs- Over 18,500 rpm.
Valve train- 4 valves per cylinder, pneumatic valve system.
Injection system- Honda PGM-FI.
Throttle system- Electronic hydraulically-operated system.
Ignition system- Honda PGM-IG.
Original von MicroBug
Hoffentlich macht Honda dieses Jahr endlich die scheiss Roten platt. Honda hat auf jeden fall das Potential dazu.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »stevie« (18. Januar 2005, 23:30)
Naja, es ist ja nicht so, dass ich es den roten nicht gönne. Aber mal im ernst, so langsam wird es doch echt langweilig.
Also nun schätzt mich nicht falsch ein. Aber ich finde Ferrari muss unbedingt mal von diesem hohen Roß runter.
Original von Funky
lol - und da hab ich aufgrund des Avatars doch schon fast gedacht das erste Bug-Posting wäre von Dir, Green!)
