Schon richtig dramatisch, was einem Bekannten von mir in USA mit seinem neuen NSX passiert ist.
Der Hammer.
Ich setze mal den Originatext in Englisch hier rein:
Kann
The issue is that the car pulls over 40mph and won't drive straight. First they said tires were defective. Then they aligned car twice. Suffice to say I've had 10 tires installed in a matter of two months and 1,500 miles. I haven't driven the car since December. Acura did not answer my initial complaint through the Attorney General office which meant they defaulted and I didn't have to allow another repair attempt. They did send a field engineer to drive the car who confirmed the problem. The switched out my wheels and tires and the car still pulled. They put mine on anther car and it didn't pull. I told them they couldn't touch a thing so they gave it back with the report. What's strange is that at first it pulled to the right, and now it pulls to the left. I think it's a sensor or something with the hybrid drivetrain that is causing uneven speeds at different corners. You can feel the car fighting it self. You can see it moving right and left as you are driving it. It's very strange.
I also had multiple other problems associated with the brakes, t-stat, bad wind noise, rattles, squeaks, and the car would throw warnings about drivetrain failure. There are way too many computers in the car, and all of them have to operate in sync. Kind of like a the Space Shuttle. If one systems detects a fault, they all go into limp mode to protect the machine.
I wish I could tell you more, but I'll probably never learn what the problem was.
I'm going to look up the VIN in the future to possibly find out happened.
56 Besucher
